My cute little button to sign up for my newsletter is not showing up in my cart. The image needs to be secure. How do I do this?
Sandra
Page 1 of 1
Gif Or Jpg On Secure Server?
#2
Posted 20 August 2006 - 05:39 PM
Create a link to the image using the following example:
https://serverxx.tot...lder/image1.jpg
- replace xx with your server number (shown at the top of the cpanel)
- use your cpanel user name
- identify the folder where you have your images stored (sample has image_folder)
Oh, by the way, if you have the hot linking protection turned on, you must put in your shopping cart as allowed to access the image.
Samantha
SamiSite.com CSB and WYSIWYG program tutorials
Feel free to right click the silly little forum images I use and save them to your own website space.
Then link to your own site. Please don't hotlink to my website to use the images. Thanks!
#3
Posted 21 August 2006 - 02:59 AM
My cart is in a folder called /shop.
Do I just add this folder, or do I have to add the php query extension that follows?
sandra
sandra
#4
Posted 21 August 2006 - 08:20 AM
Where is the IMAGE you want to display located is the main question you need to ask and answer.
If the image you want to show on your secure page is in the shop directory, you would link to it like this:
https://serverxx.tot...shop/image1.jpg
If the image is stored in a folder called images then it would look like this:
https://serverxx.tot...ages/image1.jpg
If you have your image stored in a folder called images INSIDE the shop folder then you would use this:
Same formatting. You just adjust it to fit YOUR website, your server and where your image is located.
You can have the shop files pull in an image that is stored in a different directory without a problem.
Samantha
Share this topic:
Page 1 of 1
Help
