What Is Joomla? How Can It Help Me W/ E-commerce?
#1
Posted 20 March 2006 - 02:32 AM
Ok, what is it and how will it help me with my e-commerce site? I know VirtueMart is an e-commerce package that works with Joomla. Will we have access to this as well?
Thanks.
Sandra
#2
Posted 20 March 2006 - 08:06 AM
That doesn't stop you from downloading and installing it though.
Lead Forum Moderator
TotalChoice Hosting, L.L.C.
Webhosting by Total Choice Web Hosting - General Support Forum
I am the Lead Forum Moderator. While I can assist in answering most of your hosting related questions, I am unable to answer questions about specifics relating to your account such as billing and server related issues. Should you need assistance in these areas, please contact our Help Desk or our many other options. Another good place to find answers is with our help pages, tutorials and movie tutorials.
#3
Posted 20 March 2006 - 10:27 AM
I am not sure of the interaction between the two, but if its like any other commerce package that joomla supports, its fits in snug into it. Basically you build the shop in the commerce package (might even be able to control it in joomla) and build the rest of the website in joomla itself.
I love joomla and rate its as one of the best CMSs i have found to date
JimE
#4
Posted 21 March 2006 - 12:49 AM
I'm just trying to find the easiest to use commerce site. Zen Cart has proven to be difficult for me. I'l keep looking.
Sandra
#5
Posted 21 March 2006 - 11:00 AM
You can try OScommerce. Again, this will tailor nicely into Joomla. Infact there are quite a few nice commerce ones which will fit nicely into joomla.
Good luck in choosing and let us know which one you choose!
JimE
#6
Posted 21 March 2006 - 09:13 PM
JimE
does Joomla take the place of the the commerce admin panels? Because I have found Zen Cart and OSCommerce very difficult to work with. Their admin panels aren't very user friendly.
Sandra
#7
Posted 22 March 2006 - 07:29 AM
From what I can remember, the plugin part for joomla allows control over the cart, so the answer to your question is yes. How good these are depends on the plugin for it.
JimE
#8
Posted 10 April 2006 - 07:47 PM
I installed Joomla, and downloaded VirtueMart. Where in earth do I install it though? I' already lost.
sigh.
Sandra
#9
Posted 11 April 2006 - 09:53 AM
Looking at the website here:
http://virtuemart.ne...n=com_simplefaq
VirtueMart is a component. Therefore, log into the administrator's part of joomla.
http://domainname/administrator/
This is where you control your website so to speak. Now goto installers and then components. Use this area to upload your component virtuemart. Once its installed itself, it can be found under the tab "components" in the main menu, here you will be able to do what you like with it!
Have fun playing with it!
#10
Posted 11 April 2006 - 11:13 AM
#11
Posted 11 April 2006 - 11:26 AM
#12
Posted 12 April 2006 - 06:30 AM
Its possible give or take a small amount to get most of Joomla not to show.
If you have upload the component and its showing in the component tab, then the next step will be to make a link to access it.
If you go to menu manager and select the menu, you want to edit, you will need to find the icon to edit the menu items. Once you are in this, goto "new", then "link to component", then choose the newely installed component and give it a name and then click "save".
Reload your front page and you should havea link to the new shoping cart.
JimE
Sign In
Register
Help
MultiQuote
