I have a zen cart folder within my "shop" folder. How can I move it or delete it so "shop" contains the files?
I don't want this to be my URL:
http://www.debutante...elease-patched/
I want this:
http://www.debutanteclothing.com/shop
Thanks!
Sandra
Page 1 of 1
How To Move Zen Cart Into Shop Folder?
#2
Posted 08 January 2006 - 04:25 AM
I would generally move the complete folder (you can do this in file manager in cpanel) and then just modify the config file to show the correct directory.
Andy Beckett
#3
Posted 08 January 2006 - 04:32 AM
Hi andy!
The zen cart folder is already a folder within the shop folder. Should I extract all the files and place them in the shop folder?
#4
Posted 08 January 2006 - 05:55 AM
I would just move the folder - rather than each individual file.
If you move the Zen cart folder to public_html, then delete the shop folder, then rename the Zen cart folder to shop is probably the easiest.
Andy Beckett
#5
Posted 08 January 2006 - 06:27 PM
And then change the name of the directory in configure.php and admin/congifure.php right? any other files I need to do that for?
thanks a million Andy!
Sandra
Sandra
#6
Posted 08 January 2006 - 06:41 PM
I think it will be just those two - but if you do that and test, you'll soon see if it works
If it doesn't, paste the link where it is failing, and we'll have a look.
Andy Beckett
#8
Posted 08 January 2006 - 10:13 PM
Just test to see if the site is working properly.
#9
Posted 09 January 2006 - 01:58 AM
Ok,I made the move.
I got this Warning:
The downloadable products directory does not exist: /home/rcxxjrfs/public_html/shop/zen-cart-v1.2.6d-full-release-patched/download/. Downloadable products will not work until this directory is valid.
What do I do?
Thanks for all the help.
Sandra
I got this Warning:
What do I do?
Sandra
#10
Posted 09 January 2006 - 02:13 AM
You need to edit shop/admin/includes/configure.php and change all the entries that say /shop/zen-cart-v1.2.6d-full-release-patched/ to just /shop/
Andy Beckett
#11
Posted 09 January 2006 - 02:16 AM
got it. I didn't properly edit the configure files because I didn't have the right permissions set.
Page 1 of 1
Sign In
Register
Help
MultiQuote
