Php.ini Override Questions
pogany
OK, I get that I can't directly edit the php.ini file on my shared server here. It looks from other posts here like I can override some values by setting them in an .htaccess file. I've got 2 options set to new values like this (I want to increase upload file size limit):
php_value upload_max_filesize 100MB
php_value post_max_size 100MB
This doesn't seem to be working. When I use my PHP application to upload files, it still won't upload anything over the 2MB limit set in the php.ini file.
The .htaccess file is in a subdirectory of my website (****/clients/). Does it need to be at root level? Or is there something else I need to change?
I notice that the post_max_size value in php.ini is set to 55MB, while upload_max_size is 2MB. Is it possible that you could set both values to 55MB? This would effectively solve my problem.
Thanks,
Sam
This is working for me now, thanks for the tips! I modified .htaccess at my root level. Now that I know it works, I can try changing at lower levels to restrict access a little.
Thanks again for quick response. This is my first post here, but I've learned a TON from reading these boards. Great resource!
Sam
