TotalChoice Hosting Family Forums: Zen-cart Problem - TotalChoice Hosting Family Forums
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
Zen-cart Problem PHP open_basedir restrictions
#1 User is offline   procrastinate
  • Family Friend
  • PipPip
  • Group: Members
Posted 20 July 2005 - 12:29 AM
After playing around w/oscommerce i decided to also install zen-cart just to compare. however, when i was setting up the instal it gave me a warning showing:
PHP open_basedir restrictions = /home/username/:/usr/local/sqmail/:/usr/lib/php:/usr/local/lib/php:/tmp
what is that? and how do i fix it?
#2 User is offline   TCH-Don
  • Volunteer Moderator
  • PipPipPipPip
  • Group: Moderators
Posted 20 July 2005 - 12:40 AM
Open a help desk ticket to the techs,
link at top of page.
Don Rosenquist
Forum Moderator
TotalChoice Hosting, L.L.C.
Web Hosting by Total Choice Web Hosting - For Your Family - Web Hosting Family!
Any links or suggestions for third party software/sites should be used at your own risk.
My opinions and recommendations are not necessarily those of TCH and TCH is not responsible.
I am a Forum Moderator and a volunteer. While I can assist in answering most of your hosting related questions, I am unable to answer questions about specifics relating to your account such as billing and server related questions. Should you need assistance in these areas, please contact our Help Desk.
treasure your pets
The Turtle says "A little knowledge is a dangerous thing,
so keep learning!"
#3 User is offline   procrastinate
  • Family Friend
  • PipPip
  • Group: Members
Posted 20 July 2005 - 12:46 AM
ook, thanks.
another question, also when setting up the install for zen-cart - it told me to turn off register globals.... but after i did that, i couldn't go to my oscommerce anymore. it complained: "FATAL ERROR: register_globals is disabled in php.ini, please enable it!"
so can you have oscommerce and zen-cart installed/running simultaneously?
#4 User is offline   TweezerMan
  • Immediate Family
  • PipPipPipPip
  • Group: Members
Posted 20 July 2005 - 03:16 AM
I'm guessing you turned off the register_globals setting by putting the following in the .htaccess file in your /public_html directory:
php_flag register_globals off
Create an .htaccess file in the directory where you installed zen-cart. Remove the above directive from the .htaccess file in the /public_html directory, and place it in the .htaccess file that is in your zen-cart installation directory. This will turn off register_globals just for zen-cart, and leave them enabled for os-commerce (and the rest of your web site).
Hope this helps...
David Phillips (TweezerMan)
The Tweezer's Edge v3
#5 User is offline   procrastinate
  • Family Friend
  • PipPip
  • Group: Members
Posted 20 July 2005 - 11:32 AM
oic, thanks david! :)
#6 User is offline   procrastinate
  • Family Friend
  • PipPip
  • Group: Members
Posted 20 July 2005 - 10:12 PM
hmm...how do i access the admin page for zencart?
i typed in "mysite.com/catalog/v1.2.5/admin/" which is what i thought it was after i installed it...but it says url not found. also, after i opened a help desk tic w/tech support they helped me w/the installation but zencart kept giving me a warning saying that my site was insecure cuz i had the default admin settings...after tech support help me fix a few things it said url not found. they then fixed it again and it worked (warning still there)...but all the links on the admin page (to set up products/categories/shipping, etc) didn't work....they said they coudlnt' help me anymore and referred me back to the forum...but now i can't get to the admin page anymore....did i type the wrong url?
#7 User is offline   procrastinate
  • Family Friend
  • PipPip
  • Group: Members
Posted 20 July 2005 - 10:14 PM
oh maybe i should add that mysite/catalog/v1.2.5/ is where i installed zencart
#8 User is offline   procrastinate
  • Family Friend
  • PipPip
  • Group: Members
Posted 21 July 2005 - 01:47 AM
this is the error:
Not Found
The requested URL /admin/login.php was not found on this server.
somebody please help!!! :( :surrender:
#9 User is offline   TCH-Don
  • PipPipPipPip
  • Group: Moderators
Posted 21 July 2005 - 02:03 AM
Try using your cpanel > filemanager or an ftp program to browse to the cart folder and look for the admin file.
Don Rosenquist
Forum Moderator
treasure your pets
so keep learning!"
#10 User is offline   procrastinate
  • Family Friend
  • PipPip
  • Group: Members
Posted 21 July 2005 - 02:04 AM
the login.php file?
it's there...under the admin folder.... =\
#11 User is offline   procrastinate
  • Family Friend
  • PipPip
  • Group: Members
Posted 21 July 2005 - 03:08 AM
ok n/m scratch all that....i reinstalled zencart and it works now.... :D
but when i go to my admin page i get this warning:
Warning Warning: Your Admin login is not secure ... either you still have default login settings for: Admin admin or have not removed or changed: demo demoonly
The login(s) should be changed as soon as possible for the Security of your Shop
For additional Security for the Admin please see the /docs
i read the /docs on security for admin and am kinda confused on what im' supposed to do...can someone please explain? am i supposed to change the folder name of "admin" to somehting else or am i supposed to do something to the configure.php files?
thanks
#12 User is offline   TCH-Don
  • PipPipPipPip
  • Group: Moderators
Posted 21 July 2005 - 03:12 AM
I am guessing you need to change the admin password from the default?
Don Rosenquist
Forum Moderator
treasure your pets
so keep learning!"
#13 User is offline   procrastinate
  • Family Friend
  • PipPip
  • Group: Members
Posted 21 July 2005 - 03:25 AM
i was trying to do that first but coudln't find it that's why i got so confused...but i went back again and found where to change the pw....it works now....sorry for all the stupid confusing questions! :(
thanks a lot don! :)
#14 User is offline   TCH-Don
  • PipPipPipPip
  • Group: Moderators
Posted 21 July 2005 - 03:06 PM
No problem :)
Don Rosenquist
Forum Moderator
treasure your pets
so keep learning!"
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
