Gallery/imagemagick Problems No image upload after Gallery upgrade
#1
Posted 14 January 2005 - 05:10 PM
1. Gallery's Configuration Wizard reports:
"Missing optional binary composite. Without composite gallery will not be able to watermark images, except you use NetPBM and have the pnmcomp binary installed. 2 of 3 ImageMagick binaries located." - seems like this is ok
2. Gallery's ImageMagick diagnostic wizard reports:
"Your ImageMagick directory (/usr/local/bin) is not in your open_basedir list
/home/exampleusr/:/usr/lib/php:/usr/local/lib/php:/usr/local/sqmail/:/tmp
The open_basedir list is specified in php.ini.
The result is, that we can't perform all of our basic checks on the files to make sure that they exist and they're executable." - I have no idea what this means...seems bad
3. The final confirmation for Gallery's Configuration Wizard reports:
"Note: Your server has the PHP open_basedir restriction set, and certain of your paths are not in the list of restricted paths (/home/exampleusr/:/usr/lib/php:/usr/local/lib/php:/usr/local/sqmail/:/tmp) This doesn't mean that they won't work, however it does mean that we can't verify that the paths are correct. If you are unable to upload photos correctly, please refer to the FAQ and to the diagnostics to resolve your problems." - same as #2, but different description
4. The FAQ entry listed in #3
http://gallery.menal...install.faq.c.2
5. I followed their advice, and tried running Gallery in debug mode, uploading a single picture. I tried a couple of different pictures, and received the same pile of messages each time:
+ Lots of "convert: no decode delegate for this image format" messages
+ "sh: line 1: html2ps: command not found"
+ "convert: Delegate failed `"html2ps" -U -o "%o" "%i"'."
+ Three of "convert: Not a JPEG file: starts with 0x24 0x49."
+ "convert: Not a JPEG file: starts with 0x32 0x30."
+ Ending with "Error: Unable to make thumbnail (0)"
Much of this is over my head. I have had good luck with Gallery up until now. Any help would be much appreciated.
Best,
David
#2
Posted 14 January 2005 - 05:28 PM
Someone should be along that can shed some light on those errors.
Lead Forum Moderator
TotalChoice Hosting, L.L.C.
Webhosting by Total Choice Web Hosting - General Support Forum
I am the Lead Forum Moderator. While I can assist in answering most of your hosting related questions, I am unable to answer questions about specifics relating to your account such as billing and server related issues. Should you need assistance in these areas, please contact our Help Desk or our many other options. Another good place to find answers is with our help pages, tutorials and movie tutorials.
#3
Posted 15 January 2005 - 04:15 AM
http://gallery.menal...order=0&thold=0
"It has come to our attention that the ImageMagick development team recently modified the commandline parameter requirements for their most recent versions. This causes ImageMagick 6.1.0+ to be incompatible with Gallery 1.x in some circumstances.
If you see errors, while using ImageMagick, that are similar to those described in this bug on SourceForge, then you will need to downgrade your version of ImageMagick to something below 6.1.0.
This error will be resolved in the upcoming 1.5 release of Gallery, and if absolutely necessary, we will release a fix for 1.4.4. There are no plans for a 1.4.4 fix at this time."
#4
Posted 26 January 2005 - 04:08 PM
Best,
David
#6
Posted 01 February 2005 - 11:10 AM
Warning
Missing optional binary pnmcomp. Without pnmcomp gallery will not be able to watermark images, except you use ImageMagick and have the composite binary installed.
12 of 13 NetPBM binaries located.
Warning
Warning
I can't find jhead. If it's installed and not in the path of the webserver user that's OK—you can specify the path by hand on the following page. If it's not installed, you can install it yourself. Jhead is a public domain EXIF parser. Source, linux binaries, and windows binaries can be found at the jhead homepage.
Can't find jhead
Warning
I can't find jpegtran. If it's installed and not in the path of the webserver user that's OK—you can specify the path by hand on the following page. If it's not installed, you can install it yourself. Jpegtran is a free tool distributed by the Independent JPEG Group as part of libjpeg. Source may be found at the IJG homepage. Binaries may be found at the JPEG Club website or in the libjpeg package of Linux distributions.
Can't find jpegtran!
Then it says, "Your installation passed with flying colors! Go go go!"
I select ImageMagick and I point it's path to "/usr/local/bin". I searched the forums and everyone says it's the correct path.
Then I go into Gallery Diagnostics: Check ImageMagick, and I get the same message David gets above:
Note: Your ImageMagick directory (/usr/local/bin) is not in your open_basedir list
/home/movemen:/usr/lib/php:/usr/local/lib/php:/tmp
If it mentions open_basedir then it's because your system is configured with open_basedir enabled. You should talk to your system administrator about this, or see the Gallery Help Page.
That's where I am right now. I've checked the Help Page and a lot of it's too deep for me to comprehend. Wondering if others have similiar problems and how they were ultimately solved.
steve
#7
Posted 01 February 2005 - 11:17 AM
Please open a help desk ticket (link at top of page) and give them the same detailed information you just posted here and I'm sure they can help get it sorted out.
#8
Posted 02 February 2005 - 12:33 PM
Thanks Bruce for the welcome.
So I've openned to and received a response to my ticket regarding this issue. By the way, I've managed to resolve most of the warnings by finding and installing the scripts that were asked for, so there's no problem there. I still can't get my images and thumbs to show up when I upload an image. The response to my Help Ticket said:
Quote
ImageMagick binaries are present under /usr/local/bin/ directory. You can safely ignore this warning and install the software. Please get back to me with the example links if you experience any issues after the installation. Alternatively, you can search for an updated version of the gallery software.
So my ImageMagick path is correct, and I'm using Gallery 1.4.4-pl5 (lasted version). I also came across this discussion which coincides with the response I received:
http://www.totalchoi...showtopic=13717
Do I have any other options but to wait until Gallery's next build and hope they account for it? Has anyone gotten 1.4.4-pl5 to work on tch?
-steve
#9
Posted 02 February 2005 - 01:23 PM
A couple weeks ago I installed 1.4.4-pl4, when I read this post, I went and downloaded the newest version, 1.4.4-pl5 and just finished installing it and it appears to work fine.
On the first page of the configuration wizard, I ignored all the warnings and just continued. I selected ImageMagick and used this path: /usr/local/bin (I just checked my config.php and confirmed, there isn't a trailing slash).
Hope that helps!
#10
Posted 02 February 2005 - 04:31 PM
My 'Albums URL' wasn't correct, even though my 'Albums Directory' was. My bad - sorry for all the drama.
-steve
#11
Posted 02 February 2005 - 04:34 PM
Welcome to the family!
#12
Posted 02 February 2005 - 07:11 PM
and your new home!
So if you need anything,
just ask your new family!
We love to help
Forum Moderator
Web Hosting by Total Choice Web Hosting - For Your Family - Web Hosting Family!
Any links or suggestions for third party software/sites should be used at your own risk.
My opinions and recommendations are not necessarily those of TCH and TCH is not responsible.
I am a Forum Moderator and a volunteer. While I can assist in answering most of your hosting related questions, I am unable to answer questions about specifics relating to your account such as billing and server related questions. Should you need assistance in these areas, please contact our Help Desk.
treasure your pets
The Turtle says "A little knowledge is a dangerous thing,
so keep learning!"
Sign In
Register
Help
MultiQuote
